It is currently Sat 06. Jun 2020 6:28:08
 Post subject: Cyclic Ring
PostPosted: Tue 14. May 2019 20:47:05
So, after adjusting the cyclic ring to where it should be, I get different degrees for aileron and elevator on each side. For instance I get 8 on one side of the elevator while 10 on the other. The collective is fine and servos are 90 degrees except for one because the horn couldn't get exactly with 90 on the server so subtrim was used. Should I use the TX travel adjustment to fix the one side? Should I be concerned about this or does it really matter?
Thanks for any help.
 Post subject: Re: Cyclic Ring
PostPosted: Wed 15. May 2019 18:45:25
to resolve this issue, you can use Servo Travel Correction.
The most precise guide for configuring the mechanics is described here:
http://manual.spirit-system.com/index.p ... tive_Pitch
PostPosted: Wed 15. May 2019 19:33:13
I thought that was only suppose to be used for collective?
PostPosted: Wed 15. May 2019 21:17:32
No, this will help with all possible issues of the mechanics.
PostPosted: Wed 15. May 2019 21:58:57
ok, thx.
