It is currently Fri 29. Mar 2024 16:19:22
[ 4 posts ] |
sputnic6
Posted: Tue 14. May 2019 19:54:38 |
I'm getting slight tail wag with the following setup: Goblin 700 gasser BK BLS-8005HV tail servo rudder delay 0 rudder gain 38 Overall gain multiplier 1.0
If tired reducing the gain with no success. The mechanical is 90 degrees on the servo horn. Any help would be appreciated
sputnic6
Posted: Tue 14. May 2019 21:15:36 |
I should also mention this happens in hover at 1900rpm, 2000rpm, and 2100rpm. From what I noticed, I do not get a wag doing pitch pumps.
Posted: Wed 15. May 2019 21:16:11 |
please try to increase Pirouette Consistency to 180 while decreasing Gyro Gain little bit. Also using a shorter servo arm could help.
Make sure the unit is mounted really hard and can't move in any direction, especially to yaw due to vibrations.
sputnic6
Posted: Mon 20. May 2019 15:41:22 |
I need to rebuild the engine. After that, I will try those settings.
[ 4 posts ] |
