It is currently Sun 26. Jan 2020 19:04:46
PostPosted: Tue 14. May 2019 19:54:38
I'm getting slight tail wag with the following setup:
Goblin 700 gasser
BK BLS-8005HV tail servo
rudder delay 0
rudder gain 38
Overall gain multiplier 1.0
If tired reducing the gain with no success. The mechanical is 90 degrees on the servo horn. Any help would be appreciated
PostPosted: Tue 14. May 2019 21:15:36
I should also mention this happens in hover at 1900rpm, 2000rpm, and 2100rpm. From what I noticed, I do not get a wag doing pitch pumps.
PostPosted: Wed 15. May 2019 21:16:11
please try to increase Pirouette Consistency to 180 while decreasing Gyro Gain little bit.
Also using a shorter servo arm could help.
Make sure the unit is mounted really hard and can't move in any direction, especially to yaw due to vibrations.
PostPosted: Mon 20. May 2019 15:41:22
I need to rebuild the engine. After that, I will try those settings.
