It is currently Sun 07. Jun 2020 7:17:25
PostPosted: Sat 04. May 2019 10:00:08
Hi everyone, I have a problem with the Geolink module connected to my Spirit unit.
When the Spirit software in the Geolink setting section opens the first information shows me the module is connected, fixed and updated to firmware version 1.0.2 by going to the Map section (the only working tab), the position and the coordinates is displayed correctly. The problem occurs in all the other tabs: Module, Aid, Update which by opening causing crash the software showing a precarious connection error with no possibility of doing anything, I am forced to disconnect the USB interface and restart the Spirit software.
All connections are correct, I followed the manual step by step and the helicopter flies perfectly without Geolink, the problem is only the programming Geolink by software that does not allow any operation, not even the calibration request.
I also tried to flash the latest firmware available for Geolink but without success because even during the update the software crashes.
I have attached a video in italian which explain the problem:
https://drive.google.com/open?id=1Rm3F5 ... 8Xq_41B6rV
I hope you can help me to solve this problem.
Thank you
PostPosted: Thu 09. May 2019 7:31:59
I have sent you a private message with a possible solution. Please let us know.
PostPosted: Tue 21. May 2019 9:16:32
Thank you
ciao, ho lo stesso problema, sei riuscito a risolvere?
PostPosted: Tue 21. May 2019 9:42:04
Yes, problem was resolved.
