So I did 3 flights yesterday and when I went to use the hard deck (alt limit with recovery) it just took off up , up and up it went till I knew something was wrong and flipped the switch back. Went to check the logs after and found this. Anyone else ever have this problem? it was working just fine awhile ago. anyways here are some screen shots and logs..
spirit-log-2019-03-31-140035.pdf [74.84 KiB]
Downloaded 57 times
spirit-log-2019-03-31-144434.pdf [65.33 KiB]
Downloaded 58 times
Downloaded 58 times
Downloaded 58 times
Downloaded 58 times
