It is currently Sat 06. Jun 2020 4:36:27
 Post subject: uSpirit - power capacity
PostPosted: Sat 12. Jan 2019 18:11:18
I would like to use a uSpirit I already own on a Blade 270 which uses the Spektrum H3050 and H3060 servos. Are those servos going to pull to much current for the power-bus in the uSpirit?
I believe these servos are the same as what is used with the 230s.
Thoughts...
PostPosted: Sat 12. Jan 2019 20:31:21
They are just fine for uSpirit.
uSpirit can handle micro servos without any problem.
PostPosted: Mon 14. Jan 2019 20:37:56
I have the doubt if the uspirit can go well in a minicomet, by size I would be much better, is it possible?
PostPosted: Mon 14. Jan 2019 22:44:35
You will need 4x JST-Servo adapters. Then it will work. But normal Spirit unit is just fine for Mini Comet.
