It is currently Sat 23. Feb 2019 3:55:45
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Wed 11. Jul 2018 12:46:29
Thank you for the video. Yes, indeed it is wrong behavior.
Could you please send also your current settings?
Please check if your Throttle channel is assigned in the Channels window (usually to Channel 1). Because if it is not assigned, then unit can't know when main rotor is spinning. Instead it is verifying by vibration level and stick movement (whether the model is flying) but this is usually not fast enough.
PostPosted: Wed 11. Jul 2018 17:39:46
throttle is on channel 1
thank you for helping.
130.4ds [255 Bytes]
Downloaded 12 times
PostPosted: Fri 13. Jul 2018 20:05:10
i've made a sticky mix on my taranis, to pump in some quick rudder for the time being.
Gonna test that out tonight.
PostPosted: Sun 15. Jul 2018 15:49:02
Thank you for the details.
I can't find anything wrong.
But if you still can't make it work I can provide you a new firmware/software which should help, also regarding performance.
PostPosted: Tue 17. Jul 2018 15:30:50
a new firmware would be great, thank you
PostPosted: Tue 24. Jul 2018 7:22:41
We have sent email to you with the details.
Thank you for your patience!
Users browsing this forum: Google [Bot] and 9 guests
