It is currently Thu 28. Mar 2024 18:34:21
[ 3 posts ] |
onebigjunker
Posted: Sat 09. Jun 2018 20:59:50 |
Am I missing a setting, causing motor to fade in and out after take off, in my gaui x3, I have changed esc to hobby wing with 7 amp bec. Still does it am I not supplying enough power or what?
Dawiev
Posted: Sat 09. Jun 2018 21:36:34 |
Maybe post more details about your setup, logs etc ?
Posted: Sat 09. Jun 2018 21:39:33 |
from your description it could be caused by enabled Governor in the Spirit unit while ESC has also enabled internal Governor. So there are two governors enabled at the same time, which will result in described behavior.
Please verify your settings - General tab/Governor window.
With your settings file attached it would be perfect.
[ 3 posts ] |
Users browsing this forum: franz88 and 1 guest |
