It is currently Thu 28. Mar 2024 17:46:30
[ 5 posts ] |
rolandk
Posted: Tue 08. May 2018 8:55:20 |
Hello all together, I flew yesterday with my TRex 550X (Spirit Pro, Setup mostly default settings). Wind speed was approximately 25 km/h. After or while a climb with full pitch I wanted to make a rudderturn to right side, but the heli did not or only very slowly react to the input. Left rudderturn was o.k. I tried then rudderturns in both directions in normal pitch positions and all was o.k.
Is this “weakness” of right rudder a normal behavior because of the torque of mainrotor or have I to change my setup? Thank´s in advance for every hint and with best regards
Roland
Posted: Tue 08. May 2018 9:05:17 |
this could happen, if the head speed is too low / rudder efficiency is too low. If it is mechanical issue, you can only increase the RPM or use a longer tail blades. If it is configuration related, then you can increase Pirouette Consistency by 10 - 20 points to make it better.
It depends on what RPM you are flying?
rolandk
Posted: Tue 08. May 2018 9:53:06 |
Hello Tomas,
thank You very much for the quick reply. Align offers für this Heli tail blades with 90 mm and 95 mm. I ´m the 95´s. Head Speed RPM was 2000 rounds in Spirit Governor Mode. I think, I will try to increase Pirouette Consistency and will give a feedback then
With best regards
Roland
Posted: Tue 08. May 2018 9:55:47 |
You can try to increase to 2200 - 2300 RPM. This should be optimal headpseed for this helicopter. For 3D they are using even 2500.
rolandk
Posted: Tue 08. May 2018 10:23:34 |
O.k, thank You.
I will try this too.
[ 5 posts ] |
