It is currently Tue 22. Jan 2019 6:48:44
Post new topic Reply to topic  [ 291 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 30  Next
 Post subject: Re: GPS?
PostPosted: Tue 15. May 2018 14:24:56
toto_gt wrote:
Sakuji wrote:
ZeXx86 wrote:
Well done, this should work pretty well.
Just make sure it is made from plastic. A bigger/massive conducting parts such as carbon frame, aluminium or similar are not optimal for GPS signal.
But for GPS modules the most parts are made from plastic, so linked stuff will work well.
We want some videos, Tomas.
Please? :D
I'm picking some of these. Colored black that will blend better on the boom. https://www.amazon.com/dp/B071WW8P83/ref=psdc_507844_t2_B003L16ZYU
Well i would prefer to have my own unit , instead of watching vids.
That's even a better option.... Now you ask Tomas to do that....
PostPosted: Tue 15. May 2018 16:09:11
Tomas
On a related note. Do you plan on releasing replacement cases for the modules being that they are pretty exposed at the tail boom area? The way your module is designed it seems it is a user serviceable item in terms of replacing the case.
PostPosted: Thu 17. May 2018 13:37:27
Sakuji wrote:
Tomas
Sakuji, I wouldn't worry about it. The whole point is not crashing the heli unless it is hardware fault.
I think he will do something if it ever happen. And you can 3d-print the case even though it might not look kool.
PostPosted: Thu 17. May 2018 13:39:32
For sure we can provide spare enclosures. You are right that it is easy to replace (just few seconds).
PostPosted: Thu 17. May 2018 15:24:31
RedJacket wrote:
Sakuji wrote:
Tomas
That's the point, there are certain instances of crashing due mechanical/electronic problems. Remember those Oxy4 tail failures or overcurrent shutdown?
It's a legitimate question on a possible scenario specially that the boom is the preferred location similar to the Skookum or any other gps device ever introduced on rc heli.
PostPosted: Thu 17. May 2018 15:26:14
Perfect, Tomas!
Now, if can we just get our hands on those geolinks. Lots of us here have been drooling :D ...
PostPosted: Thu 17. May 2018 19:04:34
hello,
what do you think about my mounting position? It is far away from the Motor. The canopy is only plastik and there is no metall or cfk next to the modul. It is right next to the Spirit Pro and away from the Rotor Head. There is only one servo 5cm away.
Is there a option where i can see if the signal is good or bad?
PostPosted: Thu 17. May 2018 19:20:51
It will very likely work there, but for sure tail boom would be better.
Any nearby metal and electronics is bad if you want to achieve the best performance.
Yes, it will be possible to see signal quality / precision. Even if you will mount GeoLink at the worst possible place, it will work somehow since it has exceptionally sensitive antenna.
GeoLink is even able to get signal indoor without any help of network, but precision is directly dependent on the signal quality.
PostPosted: Thu 17. May 2018 19:29:06
ok, thank you for your help. :D
PostPosted: Fri 18. May 2018 4:10:28
Any idea when units will be sent out ?
Thanks.
Sent from my SM-N910W8 using Tapatalk
