It is currently Fri 22. Mar 2019 18:04:32
 Post subject: Tail endpoints slider
PostPosted: Tue 15. Mar 2016 8:46:13
One small thing. If you click for example on the left tail endpoint adjusting slider it would be logical if then it would move the tail slider to it, but it only does if you raise or lower it one point. A little bit weird if youre checking your endpoints.
PostPosted: Tue 15. Mar 2016 8:53:44
The best thing is you click on the slider to activate the "focus" and then use the keyboard arrow keys to change the values.
This has the advantage of allowing you to set your endpoints while looking at the tail, no need to operate a mouse or look at the screen, just two fingers on the arrows.
To have the slider move to see current limit when you start, just quickly do right/left arrow, so the value is unchanged and the slider moves.
And you can use TAB to move from the left to the right limit, and SHIFT+TAB to move back.
Same principle applies of course to the Servo tab Subtrim feature.
PostPosted: Tue 15. Mar 2016 9:39:05
Yes, however I would expect it to move to the endpoints when the slider is focussed :)
PostPosted: Thu 05. Oct 2017 20:12:18
+1
The way it currently does nothing until it is moved is just weird.
It would be a very easy fix in the software.
Sent from my SM-J320FN using Tapatalk
PostPosted: Thu 05. Oct 2017 20:36:12
That is nice idea. It could be done with clicking.
With focus only it would be very risky, because if you configuring new model and you are just looking at it it could unexpectedly hit mechanical limit and cause possibly some damage.
So only when there is real intention to do something with limits it should move. Clicking (without a value change) should be good.
It will be in the next update.
PostPosted: Fri 06. Oct 2017 2:13:10
Awesome! Thank you.
PostPosted: Tue 19. Feb 2019 22:43:56
This doesn't appear to be in the latest release.
