It is currently Tue 28. Jan 2020 22:01:16
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2, 3  Next
 Post subject: SRXL2 Technology
PostPosted: Sat 16. Nov 2019 21:48:45
hi will Spirit support the new spektrum SRXL2 protocol
will this rx be compatible :
http://spektrumrc.com/Products/Default. ... D=SPM4651T
 Post subject: Re: SRXL2 Technology
PostPosted: Sat 16. Nov 2019 22:30:24
Yes, it will be compatible.
PostPosted: Tue 26. Nov 2019 1:13:16
The new SRXL2 Remote Serial Receiver with Telemetry (SPM4651T) looks interesting. However, Spektrum and Horizon have limited information.
How will it connect to Spirit? What cable(s) needed?
HH website lists "SRXL2 Remote Receiver Extension", available in several lengths on the product page below, but no pictures and no instructions.
https://www.horizonhobby.com/srxl2-remo ... y-spm4651t
PostPosted: Sat 30. Nov 2019 3:14:11
SRXL2 remote receiver uses a 4-pin connector (not 3-pin). How are we going to connect it to the satellite ports on the Spirit 2?
PostPosted: Wed 04. Dec 2019 4:46:24
Here is the manual.
https://www.spektrumrc.com/ProdInfo/Fil ... ual-EN.pdf
PostPosted: Wed 04. Dec 2019 10:27:17
It will be connected in the similar way as SPM4649T.
PostPosted: Wed 04. Dec 2019 14:23:07
Tomas, will you make multi adapter with 4-pin heads?
PostPosted: Tue 24. Dec 2019 2:36:52
So, it looks like the new SPM4651T also makes use of the NC port/wire. If we are told that it works the same way as the SOM4649T, then does that mean we should ignore the “NC” wire and connect the other three (Volt, Signal, GND) to the Jeti cable just like the spm4649? Please advise.
PostPosted: Tue 24. Dec 2019 14:38:50
N/C mean Not Connect.
Yes, we will make adapter for the new receivers. So that it can be easily plugged to the unit.
Support will be included very soon.
PostPosted: Tue 24. Dec 2019 17:06:47
Great, thanks! Will look forward to seeing an update in the manual
