It is currently Tue 28. Jan 2020 11:45:38
PostPosted: Tue 02. Jul 2019 14:17:01
Hi, my question is regarding the above metioned setup.
I use UniSens-E (under Graupner HOTT as GAM)to detect the used capacity and let the receiver tell me by using a switch.
Now - with the sprirt unit i have to decide whether i will use telemetry port for spirit setup or to use the UniSens-E unit.
My question: Is there any possible wireing to have both functions possible via the telemtry port? :?
regards
Peter
PostPosted: Tue 02. Jul 2019 16:24:26
Yes, you can use Y-cable. But before connecting of both components you have to set UnisensE or Spirit to EAM mode instead of GAM.
TDF, TDR, Logo 600, Devil 380, Oxy 4 Max @ 3Digi, VBar Neo, Spirit, Grapuner mz-32, mx-20
PostPosted: Tue 02. Jul 2019 16:27:43
See http://manual.spirit-system.com/index.p ... _Emulation how to change sensor emulation mode for Spirit
PostPosted: Thu 04. Jul 2019 19:38:23
this - i will try this - but what about the wires?
The unisons needs the red cable for power-supply. It is recommended that on the SYS-port of the spirit the must not be any voltage!!!
Did you cut the red wire or is it no problem?
PostPosted: Thu 04. Jul 2019 20:04:31
Use plus, gnd and signal between Unisens and receiver. And connect signal from receiver to Spirit. GND is already connected by another cable.
PostPosted: Fri 05. Jul 2019 7:06:00
Thank you very much - i will try this!!!
PostPosted: Sun 14. Jul 2019 7:59:12
I tried this an it works!!!!! :D :D
Great job thank you very much for your help!
Peter
