It is currently Sun 22. Sep 2019 7:00:52
PostPosted: Wed 24. Apr 2019 16:27:58
The motor only needs to spool-up when configuring the governor, so a tick box in the governor setup screen to enable the motor would be good to stop accidental spool-ups. The motor will turn off when governor setup screen is exited.
In all other screens, the motor will ALWAYS be disabled, regardless of throttle setting on the Tx.
PostPosted: Thu 25. Apr 2019 8:07:06
Then you wouldnt be able to use the vibration analysis!
PostPosted: Thu 25. Apr 2019 9:51:34
Ah yes, forgot about that. Enable the motor for that test too. But everything else should be disabled.
