It is currently Mon 13. May 2024 12:22:43
Matzer27
Posted: Tue 13. Nov 2018 13:46:15 |
I just changed from the Vstabi to the spirit pro. On the Vstabi everything was normal. With the spirit pro my tail wags violently and sometimes it kicks by about 30 deg. My setup: Tail-servo: Align DS650 Hobbywing Platinum HV 160 with 1700 rpm Gain: started with 50 % and tried down to 0 and up to 100 % Rudder 1520micros 333Hz Rudder Common Gain 1.30x Rotation speed Rudder 9 Rudder delay 5 Rudder dynamic 7 What is wrong on my setup?
eg183100
Posted: Tue 13. Nov 2018 14:19:11 |
I would set common gain to 1.0
Could you post your setup. As with gyro at 0%. You should see a difference;-)
Matzer27
Posted: Tue 13. Nov 2018 15:57:57 |
Here the Telemetry logs of the gain and the Ruder.
Attachments: |
Matzer27
Posted: Tue 13. Nov 2018 16:02:58 |
And here the Ruder
Attachments: |
Posted: Thu 15. Nov 2018 9:11:04 |
I recommend to set Rudder delay to 0. Then we dont know anything about rest of your settings. Could you attach your settings file (4ds) here, please?
Very likely the problem could be in Pirouette Consistency settings value.
When looking at the Diagnostic tab in the Spirit Settings, can you see that the Gain is really changing and reacting to your radio?
Matzer27
Posted: Thu 15. Nov 2018 12:16:58 |
Matzer27
Posted: Thu 15. Nov 2018 12:25:29 |
In the diagnostic tab I see the Gyro is moving from 0% up to +100% when a change it in the tx with a poti. I want only HH.
Posted: Thu 15. Nov 2018 12:30:49 |
Thank you for the settings.
For Spirit unit it would be better to set servo arm one hole further from the center. Then you can set Rudder Delay to 0. Gyro Gain can be configured to be around 50% for the beginning. Performance should be better after these changes.
Do you remember if you used a Revomix with VBar?
Posted: Thu 15. Nov 2018 12:44:36 |
After changing hole in the servo arm please do not forget to decrease Rudder end-points. They will be smaller now.
Matzer27
Posted: Thu 15. Nov 2018 12:49:31 |
I didn´t used a revomix with VBar. For the servo arm I already using the far end hole of it.
Users browsing this forum: No registered users and 73 guests |
