It is currently Wed 21. Aug 2019 4:43:14
PostPosted: Sat 15. Sep 2018 0:48:58
is it okay to keep the WiFi-Link always connected, wired and powered?
I guess it's okay, sorry, maybe dumb question but better to ask :)
PostPosted: Sat 15. Sep 2018 19:54:57
Yes. It is OK, but you should enable Auto-Turn Off feature in the Web interface.
Once module is turned off in this way, then it is perfectly safe.
PostPosted: Sun 23. Sep 2018 16:44:15
thanks! and I guess that also means, I need to disconnect from Spirit's WiFi network?
PostPosted: Mon 24. Sep 2018 7:05:33
Yes, you can just turn off Wifi on your phone.
PostPosted: Mon 24. Sep 2018 9:14:17
on iphone you can configure a specific wifi to not "auto-join"
so your iphone will connect on that wifi only if you choose to
i guess there is a similar setting on android too but i don't have one to check
PostPosted: Mon 24. Sep 2018 14:17:09
Yes there is.
PostPosted: Tue 02. Oct 2018 10:29:45
okay, the wifi link switches off after inactivity, is there a way to switch it on again except re-plugging the battery? I want to check the logs with my mobile but when I re-plug the battery all the logs are reset.
PostPosted: Tue 02. Oct 2018 12:49:48
disconnect and reconnect just the power plug of the wifi-link (brown+red)
PostPosted: Tue 02. Oct 2018 12:59:18
himm, thanks, but doesnt apply to my setup as wifi link is powered from the receiver which is difficult to access.
maybe I can later place a switch in between.
what if I dont enable Auto-Turn Off, but not connect to WiFi?
PostPosted: Wed 03. Oct 2018 7:27:50
The Wifi-Link will be still transmitting, so there will be increased noise with respect to your receiver/transmitter.
In the most cases it is not a problem, but could in theory reduce tx signal.
There are also electronic switches available that can turn power on/off and can be controlled by a free channel.
