It is currently Wed 13. Nov 2019 16:30:49
 Post subject: Goblin Fireball
PostPosted: Thu 24. Aug 2017 13:41:02
Hello Tomas!
Is it possible to extend the pole number up to 24 poles (12) (Goglin Fireball)? The motor is a 24 Pole: I now have 6 poles and 2.00 translation should actually be synonymous with the direct drive of the fire?
Greetings, Gernot
 Post subject: Re: Goblin Fireball
PostPosted: Thu 24. Aug 2017 14:00:09
Hello!
If gear ratio is 1.0, then your calculation is correct. Sensing divider at 6 and gear ratio at 2 will give you good result.
Update 2.5.0 will make it possible to set Sensing Divider at 12.
PostPosted: Thu 16. Nov 2017 6:02:42
Thanks, I got the divider working correct now.
On the governor, the Max Head Speed is 4000 RPM but the Max on the Mini Comet is 5000 RPM. Will the governor be able to go up to 5000 RPM at some point?
PostPosted: Thu 16. Nov 2017 8:06:44
Yes, in the next update.
PostPosted: Thu 16. Nov 2017 12:38:35
Great!
Any idea on when that might be available?
PostPosted: Wed 29. Nov 2017 17:46:57
Any Idea When will be available and also will the Fireball setup will it work for Mini Comet...
PostPosted: Wed 29. Nov 2017 21:36:27
Maybe in one month, but not sooner.
Alternatively we can send you beta version, this can work immediately. But we can't guarantee operation.
Yes, you can use Fireball setup for Mini Comet.
