It is currently Mon 13. May 2024 20:34:31
Till
Posted: Wed 28. Dec 2022 21:41:54 |
Thank you - that was very helpful. What means "you have always view the log to get normal initialization" - is it enough to look via the integration menu (what I do) or is it necessary to look through the pc-software to clear the error-memory ?
So I have the Spirit RS, the unit (reciever and fbl-unit) should turn off at the same time and i wait for the connection lost message before I turn of the radio. So I will investigate this further - what makes me a little suspicious that with my other RS units no problems arise with almost the same equipment..
Posted: Thu 19. Jan 2023 9:57:58 |
All models should be always turned off so that first battery from model is plugged off. Then radio is turned off. If it is done in opposite way then this error message will be generated and saved in the log.
Logs must be viewed with PC software to clear the error message.
Users browsing this forum: No registered users and 7 guests |
