It is currently Tue 19. Jan 2021 16:33:01
 Post subject: Fixed Angle
PostPosted: Sat 10. Mar 2018 20:24:18
hello,
i have another idea for the Spirit Aero.
A "fly by wire" control, in which it interprets the control stick deflections as command angles for Pitch and Roll. For example,
pushing and holding your control stick maybe 50% to the left will cause your model to enter a level altitude banked left turn in maybe 20° angle. The Spirit control thr angle. The RC Plane goes not more and not less angle.
 Post subject: Re: Fixed Angle
PostPosted: Sun 11. Mar 2018 18:25:13
thank you for the suggestion.
I am not sure if I understand perfectly, but I think that this function is already in the Aero.
You can set maximum angle for Stabilisation (Normal) mode by changing Direction Control Rate value.
PostPosted: Mon 12. Mar 2018 22:42:13
ok, i have tested it.
That was it what i meaned "Direction Control Rate"
Thank you :P
