It is currently Fri 10. Jul 2020 19:43:11
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sun 21. Jul 2019 17:05:59
ESC wiring query on SpiritPro:
I am using the standard Align BEC speed controller (RCE-BL60G) on my Trex 500 but am not sure from the manual the best way to wire this to the Spirit Pro. The manual states that with DSMX satellites (as I am using a DX8 gen2), the throttle is to be connected to the Spirit Pro unit and so am I correct that the wire from the ESC needs to go to the Aux1 unit on my spirit pro
Sorry if this is a dumb questions
PostPosted: Sun 21. Jul 2019 19:56:52
Yes BEC would get plugged into Aux 1
PostPosted: Mon 22. Jul 2019 19:38:48
thanks for this as make sense.
So when conecting the esc via the Aux1 port and with this being the the standard Align esc, given that I am using the Spektrum AR8010T receiver (connected vi SRXL port) with telem and my Dx8 gen 2 as a receiver, would i still get access to the battery voltage with this wiring or would i only get access to this if i were to use one of the 6 ESCs listed in the manual? thanks
PostPosted: Mon 22. Jul 2019 19:46:21
Correct that ESC does not support Telemetry.
You could add a Spektrum Flight Pack Voltage sensor.
Users browsing this forum: No registered users and 1 guest
