It is currently Tue 21. Jan 2020 10:25:31
PostPosted: Fri 21. Dec 2018 13:01:39
I would like to use the Aero rescue feature only, and has its gyro feature turned off during normal flight.
Is this possible?
Thanks,
David
PostPosted: Thu 27. Dec 2018 9:49:21
yes, it is possible when you set two Banks.
First where all Gains in the Sensor tab are set to 0% - for normal flight.
Second where gains are at for example 50% - default value and Stabi/Function is configured to Rescue.
Then you have to only switch between banks.
