It is currently Fri 19. Apr 2024 9:32:47
PostPosted: Sat 29. Jul 2017 10:05:23
Version 1.2.0 was released!
It brings many new features and improvements:
  • Support for μSpirit unit:
    • Full support of the µSpirit.
    • Compatible with all peripherals.
    • Can be used on planes with sub-micro to mini servos with max. current 1.5A.
    • IMPORTANT: Older firmwares are not supported!
  • Graupner HoTT integration:
    • ESC Telemetry support.
    • Telemetry connection is active also when the telemetry cable is disconnected.
    • USB interface can be connected once you will select the USB connection in the Expert menu (integration).
    • Support for μSpirit.
    • Added new Telemetry variable - Throttle PWM [ms] - reported under Climb rate.
  • OpenTX Integration:
    • Significantly faster telemetry data refresh rate.
    • USB interface can be connected without repowering the unit - once integration cable is plugged off, the status led will be turned off and you can plug in the USB interface.
    • New diagnostic script for displaying channel values - script diagnostic.lua.
    • Full support for the Log Viewer - script logviewer.lua.
    • Added new Telemetry variable - Throttle PWM [µs]
  • JETI Duplex Integration:
    • Telemetry data rate was optimized.
  • In-Flight Vibration Analysis:
    • FIX: Can be used with F: Stabi function.
    • Can be activated all the time with no downside effect.
  • ESC Telemetry:
    • Support for telemetry data from the ESC - all data can be displayed directly in your radio.
    • Available for JETI Duplex, FrSky/OpenTX, Graupner HoTT.
    • Castle Creations Phoenix and Edge:
      • Battery Voltage
      • Battery Current
      • BEC Voltage
      • Consumed Capacity
      • ESC Temperature
      • RPM
    • HobbyWing Platinum V4:
      • Battery Voltage
      • Battery Current
      • Consumed Capacity
      • ESC Temperature
      • RPM
    • Scorpion Tribunus:
      • Battery Voltage
      • Battery Current
      • BEC Voltage
      • Consumed Capacity
      • ESC Temperature
      • RPM
    • Kontronik Kosmik and Jive Pro:
      • Battery Voltage
      • Battery Current
      • BEC Voltage
      • Consumed Capacity
      • ESC Temperature
      • RPM
    • Kontronik Jive:
      • Battery Voltage
      • Battery Current
      • BEC Voltage
      • Consumed Capacity
      • ESC Temperature
      • RPM
    • Added Imotor Shunt parameter - correction factor of the Current/Capacity.
    • Added RPM - Sensing Divider parameter for a proper RPM calculation.
    • NOTE: All telemetry guides are available at the Wiki pages.
  • Wifi-Link module:
    • Support for the latest 1.2 firmware.
    • Support for the ESC Telemetry.
    • Support for the μSpirit.
    • Improved detection of the firmware version with more clear messages.
  • Spirit Settings - Android:
  • Spirit Settings - FreeBSD:
    • Launch scripts for better architecture detection updated.
    • Stability was enhanced.
  • Manual:
    • Pin layout for Spirit and µSpirit units is available.
  • Spirit Aero software:
    • News noticement:
      • Automatic noticement of a new available updates.
    • ChangeLog:
      • Scrolling in the changelog window to allow displaying a longer text.
  • Improved Setup Wizard:
    • New schemes with μSpirit.
    • Improved detection of the unit swapping.
You do not have to change any settings after the update from previous version.
Update for the Spirit units, Wifi-Link and OpenTX Integration is available in our Download section.
Users browsing this forum: No registered users and 12 guests
