It is currently Wed 22. May 2024 11:53:29
[ 3 posts ] |
DaKi
Posted: Sun 18. Jun 2023 10:34:46 |
Hi!
I have an issue where I can't switch on/off the Ch0 Output with Channel 8 of the radio. I'm using a Spirit GTR with a Jeti DS12.
In the Receiver Output window the state is always 'ON', no matter if I set max negative to -150% or not. It never changes to 'OFF'....(See Screenshot) Also, if I measure the output voltage on Ch0 it is at 1.25V and 2V respectively, which is also somehow weird.
Did anyone ever had such an issue?
Thanks!
Attachments: |
Posted: Wed 21. Jun 2023 5:45:36 |
have you tried connecting servo at the Output? It is not outputting analogue voltage signal, but PWM signal with channel value. So there is no On or Off.
DaKi
Posted: Tue 11. Jul 2023 20:06:20 |
Thanks for clarifying this!
Yes, PWM is at the output. I had it in my mind, because the Jeti receivers have this function. So, I then misinterpreted the options....
Do you think that this feature could be implemented?
Thank you!
[ 3 posts ] |
Users browsing this forum: No registered users and 5 guests |
