It is currently Thu 09. May 2024 8:49:20
[ 2 posts ] |
krm97
Posted: Mon 10. Jan 2022 1:12:04 |
I had a Castle Edge 160 ESC on my Goblin Raw in which the governor worked flawlessly. I did not use the Spirit GT governor.
I recently switched to a Hobbywing 130A HV ESC and tried using the Spirit Governor. The Spirit Governor will not activate because it wants a throttle reading above 50%. This is very unfortunate because at 42% throttle reading my RPM's are 2000rpm. Why would you ever set the governor activation at 50%?????????????????? It has nothing to do with the RPM readings on the heli. It might be somewhat predictive of RPM's but not a very accurate indicator.
Can you fix this issue?????
All the best,
Ken
HeliMLM
Posted: Mon 10. Jan 2022 8:20:14 |
Hi
if you configure the Spirit Gov, you will i.e. set your max. Headspeed value to i.e. 2.500rpms.... then 50% will be only 1.250rpms (it is always the percentage of the Max.Headspeed parameter then). what headspeeds do you like to configure?
_________________ cheers Michael
[ 2 posts ] |
Users browsing this forum: No registered users and 13 guests |
