ZeXx86 wrote:
yes, you have to make programming as described in the manual. You can verify it later with computer if you are unsure. But programming must be always done when model is not flying. It is also possible to use automatic programming for Return to Home.
There can be many reasons why GeoLink feature does not work. But without any information what you tried, what model was doing before and after it stopped working, it is very hard to help.
For example what GeoLink Status LED is doing when you land? Is it flashing? If yes, then it signalize important problem - at this moment GeoLink is not operating anymore. It must be always steady solid.
It is also better to ask question in forum thread that you created first (Support section).
This section is dedicated for Wishlist and this thread for Failsafe.
But Failsafe is there and you can program model to return to your positition if you want it already.
But model should never lost signal normally. So it is not recommended in our point of view, because it can hit somebody and even kill at areas that you already can't see.
It is not like a Drone, where radio signal is often poor after 100 meters, because transmitters are not that advanced. With helicopter there should be no second where you are loosing signal.
Return to Home is not changing Altitude. Altitude Limit is to engage rescue when falling under certain altitude. So when your collective pitch is set to make helicopter descending, it will reactivate again soon. So then model is moving up and down.
Hi, ok I will Test next time when the GeoLink functions works.
The Blue Led was all the time steady solid, I can send you Flight Log.
I asked in the support but may you see this message earlier.
They are every time more users ( WIFI ect.) with the 2.4Ghz, Europe Parlament last week authorised bigger
Band for the 2.4Ghz. I hope that never have a failsafe situation, that why I like to prevent the worst.
The pumping makes with the function GeoLink "Altitude Limit"
