The Spektrum 4649T receiver has something to do with SRXL. I'm no electronics expert, so I don't know exactly how, but this I've heard. So when I was setting up my very first Spirit not too long ago via the Wizard, I selected SRXL as the receiver type, not DSMX. That seemed correct since the Spektrum option in the Wizard lists only "Satellite" so I thought if I had anything other than a satellite I should select a different option.
It would be helpful if somewhere in the Wizard on step 1/10 it gave more info on which option to select if we're using 4649T. I spent an hour trying to figure out why my uSpirit wasn't responding to my 4649T.
The General tab is less specific/limiting to Satellites, so maybe it doesn't need altering.
File comment: General tab
The manual, though, also seems to limit my options to satellites. But I do see the "Integration" note. EDIT: At the time o was not trying to set up integration... just saying I noticed that there is more info there were I setting that up.
File comment: Manual
