near tip-over on spoolup https://www.spirit-system.com/phpBB3/viewtopic.php?f=24&t=2945 |
Page 3 of 3 |
Author: | RC_Nut [ Fri 16. Nov 2018 15:28:51 ] |
Post subject: | Re: near tip-over on spoolup |
Update.. It's looking like this might actually be a transmitter problem. I started to see some strange swash tilting on my other helis (nearly caused a crash) and I found that intermittently the Tx seems to be mixing aileron to throttle/collective. This is happening on all models i have programmed and even on a fresh model i created in the memory. So looks like decision time on the Tx, either send it away for repair/service (has to go to Germany i believe so i'd be without Tx for a while) or upgrade time.. I was kinda looking at Jeti so may be someone trying to tell me something! |
Author: | ZeXx86 [ Sat 17. Nov 2018 21:25:35 ] |
Thank you for the update. You could try to increase Stick Deadband to maybe 20. In a colder weather it is quite normal that a stick potentiometers are loosing precision and could start to drift as well. This change could help. In the worst case a pot is worn but a replacement can fix the problem. This issue will be visible in MONITOR directly in the radio. So that some stick/channel will not return exactly at the center. |
Author: | RC_Nut [ Mon 19. Nov 2018 8:24:59 ] |
Thanks for the suggestions. The Tx has been sent away to Horizon for service. They say that they recognise the issue and there is a fix for it. It is a strange one because it's not like a worn pot where the stick output doesnt centre. The aileron channel actually moves with collective as if there was a mix set between the two (there is not), even when i'm not touching the aileron stick at all . Video: |
Author: | ZeXx86 [ Mon 19. Nov 2018 8:34:40 ] |
This is really odd, but it explains all the problems. I wonder how the issue developed. Thank you very much for the video. |
Author: | RC_Nut [ Mon 19. Nov 2018 8:40:59 ] |
It was when i noticed similar issues on three different helis that it dawned on me that the Tx could be at fault. I very nearly crashed my Goblin 770 because of this. I asked Horizon to give me a report on exactly what the fault is so if they do tell me I'll post back as it might be useful for anyone having similar issues. |
Author: | LogoX2 [ Mon 19. Nov 2018 17:04:54 ] |
Might be what Spektrum calls Phantom Mixes. A fellow pilot had a brand DX18 right out the box with them crashed a brand new EDF because of it. I also had on my DX9 after deleting a mix but it never really went away, had to delete the model and start a fresh one. |
Page 3 of 3 | All times are UTC + 1 hour |
