It is currently Tue 16. Apr 2024 17:44:55
 Post subject: Chanel mapping in Spirit
PostPosted: Sat 27. May 2017 23:04:46
Hi Thomas,
im using a hott system with Gr-16 receiver and a mz-24 Sender.
As i use the sumd connection all channels are used by the system (Gyro, bank Switch included). I would like to use more than 8 channels on my gr-16 as i use the sumd connection (i need few more for led controller). But there is a issue with the channel mapping. The channels 8-12 can only be used by special functions.
It would be great if it will be possible to map the bank switching or gyro sens on chanels 8-12. Then i could use the free ports on my gr-16 via mapping to control my led controller.
Hope u understand my problem ;-)
Greetings Andreas
PostPosted: Sun 28. May 2017 10:50:28
you may try to remap the channels in your receiver.
This should be possible with GR-16 if I am not wrong.
Thank you for your suggestion!
PostPosted: Mon 29. May 2017 22:12:25
Hi Thomas,
thank you for your reply but this is not possible. If I map chanel 9 to port 1 then it goes through sumd on chanel 1.
If I could select gyro gain or bank switch to chanel 9 - 12 it would work....
Greetings Andreas
Gesendet von meinem SM-G800F mit Tapatalk
PostPosted: Tue 30. May 2017 8:22:48
Thank you for the details.
I believe it will be possible to implement it in the future updates.
PostPosted: Tue 30. May 2017 21:30:20
Thank you Thomas
