It is currently Sat 11. May 2024 21:14:19
[ 5 posts ] |
limabean1
Posted: Fri 06. Jan 2023 18:04:56 |
Hi All Would someone be able to help me understand what I'm doing wrong. I have a spirit fbl unit on a 450l with an NX8 controller. I want to put stabi function on it and as far as i can see I'm setting it up in the FBl correctly as when i activate it via the channel on the transmitter the monitor is showing that its active. The issue im having is that it will on become active on the heli swash plate when I turn the "gyro" off in the transmitter but then wont that cancel the tail authority? Help please?
Posted: Sat 07. Jan 2023 11:26:03 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 492 Location: Germany
limabean1
Posted: Sat 07. Jan 2023 20:52:56 |
Hi, thanks for the reply. I actually found what I had been doing wrong. I had to set the 60% positive gyro in the transmitter to 60% negative for the stability functions to operate. I had been watching a how to vid on the spirit and it was not mentioned so I went back and did some more reading and found what I was missing. Thanks again.
satnaam
Posted: Fri 30. Jun 2023 18:10:50 |
Can some do a proper video on the setting up stabilization and bank switching. PLEASE
satnaam
GeorgeFop
Posted: Wed 14. Feb 2024 21:36:58 |
Joined: Mon 05. Feb 2024 15:06:32 Posts: 3 Location: Russia
Has anyone experimented with creating additional support systems for Geolink to enhance its performance and stability? If so, what modifications or additions have been made and what were the results?
[ 5 posts ] |
Users browsing this forum: No registered users and 14 guests |
