Hi Vector,
So far I've only used the YGE Governor and it works very well! I don't know if the Spirit Governor is really that much better, but compared to other ESC's it's a really good one!
If you want to use the Spirit Governor, then the YGE internal governor must be deactivated in any case - In this case you need the Mode programming to Mode1 , see YGE operating instructions... Very important dismantle before all blades of the main and tail rotor so that nothing can happen !!
Follow the instruction in Spirit Manual for Governor:
https://manual.spirit-system.com/index.php?title=GovernorSince I don't have the experience here yet, I can only refer to the manual, which is what I would do if I tried the Spirit Governor - but I'm sure that some in the forum here have experience with the configuration of the governor in the Spirit FBL and can help you - I know that for example HeliMLM has quite a lot of experience with YGE, I think he can help you in any case...but of course there are others too -
Matthias
