It is currently Sat 20. Apr 2024 5:13:02
[ 6 posts ] |
DaKi
Posted: Sun 06. Sep 2020 17:05:36 |
Hi!
I have a major issue with the rescue function: If I activate the rescue(normal) mode while hovering the heli moves up in an angle/sideways instead. I tried it several times.
Since I already read some posts about similar issues I did some tests: 1) I removed the main blades and kept the tail blades mounted. Heli was placed on the carpet. 2) I activated the rescue mode right after initialization. The swashplate moved up straight without any visible angle. 3) I started the motor. ~1900 rpm on main rotor. The vibration analysis displayed no strong vibrations (max. 45% in y-axis, see attachment). Then I stopped the motor. 4) I then activated the rescue mode again. => But then, the swashplate was strongly tilted and never levelled back.
This behavior is always reproducable. Sometimes the swash moves 2 times as it would do during a real rescue action?!, but never straight up as expected. (Also nothing special in the log file: Sometimes 'Cyclic Ring' messages)
If there is no strong vibration, what could cause the rescue misalignment?
Thank you!
Attachments: |
File comment: Vibration analysis with tail blades on
Posted: Mon 07. Sep 2020 12:00:56 |
the angle could be caused by ESC fan.
Can you tell me what Spirit unit and what firmware version do you have?
Can you press CTRL+ALT+M in the Spirit Settings and write the values you see here?
DaKi
Posted: Mon 07. Sep 2020 16:41:46 |
Hi!
Thank you for the fast response! I have a Spirit 2 unit on a Logo 500. My ESC does not have a fan: Robbe Roxxy 9100-6 Soft.Ver. is 3.1.0.
I took several values, because the values scatter a bit. Right after initialization i get: -12 -10 2050 7 12 2048 While motor is running with tail blades on i get: -4419 1191 1106 5 591 1058 After stopping the motor i get: - 2 19 2052 -19 61 2038
Posted: Mon 07. Sep 2020 16:54:48 |
Thank you!
Could you please enable Expert settings / Extended signal processing please? Then restart the unit and repeat the test with rescue mode.
I hope it will help you.
Can you also let me know how the unit is mounted at the model? Is there something that is touching the unit? For example a free connector/cable.
DaKi
Posted: Mon 07. Sep 2020 18:02:02 |
Thank you!
No, there is no cable or sth. else touching the unit, I checked it beforehand. It seems to be better now. I'll try it while hovering tomorrow.
Additionally, I realized that I have stronger vibrations (75% on y-axis) if I attach the battery. For testing it was laying aside. Maybe I can get the in-flight vibration log working until tomorrow to see how it looks like during flight.
One more thing I realized: Right after initialization, if I set maximum pitch and activate rescue afterwards, the swashplate tilts to the left. This would also explain why the heli is rescued in an angle......
DaKi
Posted: Wed 09. Sep 2020 15:29:16 |
Hello!
I tried rescuing several times yesterday. What should I say, it worked! So expert settings did the trick. (Although I still don't understand the weird swash behavior on the ground)
Again, thank you very much for your help!
Btw., do I have any disadvantages keeping this option set?
[ 6 posts ] |
Users browsing this forum: No registered users and 13 guests |
