It is currently Fri 19. Apr 2024 7:41:24
PostPosted: Wed 31. Dec 2014 0:24:58
i downloaded your Software and try to run it with ubuntu.
I got the erroe message that the device could not be detected.
Code:
Linux revolution 3.13.0-43-generic #72-Ubuntu SMP Mon Dec 8 19:35:06 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
Code:
lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 003: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 003: ID 045e:0040 Microsoft Corp. Wheel Mouse Optical
Bus 005 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Code:
lsmod
Module                  Size  Used by
cp210x                 23475  0
usbserial              45014  1 cp210x
Do i need something else to run the software ?
Thank you !
PostPosted: Wed 31. Dec 2014 8:12:53
please try to start the software with settings.sh script.
This script should ask you for your password for the first time to allow users to see the device.
When launched second time, it should work.
Have a nice day!
PostPosted: Wed 31. Dec 2014 12:19:38
thank you for your answer, but the problem still exists.
the script comes up with scanning for devices and can't find any.
then it asks for demo mode.
any idea about this ?
thank you.
PostPosted: Wed 31. Dec 2014 20:17:10
Can you tell me, if this script needed your user password?
Also you can check after you attach usb interface to the PC if you can see few last words about ttyUSB device with command:
"dmesg" or "dmesg | last".
PostPosted: Thu 01. Jan 2015 13:12:27
hi ,
the problem is that the sudo call in the script does not work.
if i call the script with
Code:
sudo ./settings.sh
it work's.
i dont know why it does not work with my ubuntu. i'll take a look these days and let u know.
PostPosted: Fri 02. Jan 2015 16:58:27
Thank you very much for the info!
We will try to improve experience and add more information so it can work always correctly.
Users browsing this forum: No registered users and 11 guests
