It is currently Fri 29. Mar 2024 11:00:43
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: SRXL2 Technology
PostPosted: Sat 29. Feb 2020 6:36:38
Alyon187 wrote:
I've recently got the new SRXL 2 ex and am trying to get the rpm readout to be correct. I am seeing the increase in the rpms on the telemetry screen but it only goes up to 103. I have inputed the gear ratio of 5.70:1 (goblin 380 w 21t pinion tareq 930 motor). Everything else seems to work well. Anyone got any ideas as to how I can get the correct read out?
Sent from my SM-G965U using Tapatalk
Nevermind, I've seem to have figured it out. I had put the gear ratio in the spirit as well as the tx and only needed to input it in one place. After clearing out the other places I was able to get the correct readout on my tx.
PostPosted: Sat 29. Feb 2020 10:29:54
it is important to not set Gear Ratio in your Spektrum radio. Only in the Spirit Settings.
PostPosted: Wed 04. Mar 2020 2:57:28
I’m a bit confused. Spectrum lists the 6610t as a DSM2/DSMX receiver. It also says it offers SPRLX2 via the port only with the SPRLX2 optional satellite. So does the 6610t work with SPRLX2 on its own without satellites?
Second question: do you see a time when the SPRLX2 satellites could simply plug into the satellite ports of the Spirit rather than use the adapter cable? Will we be able to use 2 SPRLX2 satellites at one time without involving the 6610t?
PostPosted: Sat 25. Apr 2020 20:17:32
Have a quick Question I am changing over to Spirit Pro from SK-540 and I want to use a SPM4651T for the SRLX2 I think I understand the older DMSX sats I had off of the SK540 are not compatible with the new 4651 T receiver so do I NEED to have sats on this type of receiver with a 500 and if so which model sat would I get?
On the Pro I have GEOLINK on sat 2 I ordered the SRXL2 cable which will attach the 4651T where would I put this new "sat" not on Sat1 correct and I heard the adapter cable and sat port is not SRLX compatible so I can't use that I do have it if needed?
Just want to set up the new system properly any help would be great.
PostPosted: Tue 28. Apr 2020 12:19:42
hi
You should go for the AR6610T reciver,it is a full range reciver and you can use the spm4651 as remote(satellit).You can not connect any satellit to the 4651.
see this post viewtopic.php?f=20&t=3791
