It is currently Sat 11. Jul 2020 22:08:06
PostPosted: Fri 29. Nov 2019 23:22:04
:( Hello, quite suprise with new Spirit-Pro missing channel (0). We need this channel for extra power (external ubec), unfortunetly has been downgraded and quite disapointed.
Thank you... :roll:
PostPosted: Fri 29. Nov 2019 23:26:32
Its a Spirit 2, Perhaps when the new Spirit-Pro 2 comes out it will have channel 0.... :D
PostPosted: Sat 30. Nov 2019 9:51:51
by the way you can connect extra power ubec using the heavy duty Y available on store
https://store.spirit-system.com/en/acce ... cable.html
PostPosted: Sat 30. Nov 2019 12:44:22
;) Thanks guys, but quite disapointed and cancelled the order. Thank you for your respond and going to have the (old) spirit pro soon. 8-)
PostPosted: Sat 30. Nov 2019 13:38:22
There is no new Spirit Pro :)
There is new Spirit 2 which is successor of the original Spirit units.
Old Spirit units have one port less and still it was enough for running 800 class helicopter.
With Spirit 2 you can connect up to 3 BEC leads what is enough for the most helicopters.
For people that need 4 BEC/powering leads there is Spirit Pro :)
So likely it is misunderstanding in meaning of the units.
