It is currently Fri 19. Apr 2024 16:45:20
[ 4 posts ] |
Trek nut
Posted: Sun 03. Dec 2017 19:13:48 |
I have a 700 size Sea hawk from Roban models , does anyone know the gear ratio for that ? Thanks
Posted: Sun 03. Dec 2017 20:15:17 |
gear ratio can be calculated easily by equation: Main gear tooths / Motor pinion tooths = Gear Ratio
So it is only needed to know these two things, then you can calculate it.
Trek nut
Posted: Mon 04. Dec 2017 20:59:36 |
Hi Tomas ! I knew that part , but since the model has 2 stages gears that why I was lost , may be someone has the same model could give me a short cut . Thanks
goodhunting
Posted: Fri 20. Apr 2018 10:42:26 |
two stage is no brainer.... count the teeth on both gears at each stage... get the gear ratio for the first stage and multiply it with the gear ratio on the second stage... This will give you the overall gear ratio..
gh
[ 4 posts ] |
Users browsing this forum: No registered users and 14 guests |
