It is currently Mon 20. May 2024 0:30:20
PostPosted: Mon 06. May 2024 10:03:10
is it OK "on the workbench" if the full deflection of the nick/roll angle (10°) on the rotor head is already reached with approx. 1/2 of the stick travel (nick/roll) of the remote control?
If you now move the sticks further towards 2/2, the nick/roll servos simply remain stationary at 10°.
Or should the full deflection (10°) of the nick/roll angle only be reached at 2/2 of the stick travel? If so, how should I configure this? (Dual rate in the remote control or settings in the Spirit GT?)
Thanks in advance, I have done several searches in the forum but may not have found the right keywords.
Under the following post (in slovensky), a user asks basically the same thing, but has not yet received an answer. viewtopic.php?f=17&t=6072&hilit=stick+travel
Again, thank you for your support in advance
PostPosted: Mon 06. May 2024 12:16:54
the question is: in setup mode, are all the sticks shown as +/- 100% on full stick travel (or at half stick)? and ist the cycling ring configured correctly?
you cannot check stick travel & FBL deflection on the bench at all. the heli is not moving / flying and in a special mode at this time. real deflections will only show up during flight.
cheers
Michael
PostPosted: Mon 06. May 2024 12:41:33
Hello HeliMLM,
thank you for your answer.
Yes, in step5/10 all sticks are shown with +/- 100% when I move them to the related endpoints. In center they are showing 0%.
Yes, if you mean step6/10. The leveling is done by using a swash-leveler, mechanical adjustments of the the rods and measurement of 0° with a electronic tool.
Yes, I understand what you mean.
I'm wondering not about the resulting 10° but more about the situation that not the whole possible moving-way of the sticks is used for movement at this time on the workbench
Kind regards
Carsten
PostPosted: Mon 06. May 2024 17:41:06
you don't have to ask yourself this question.
The cyclic in flight behaves very well.
You have to fly and select the expo you want on your radio.
To vary speed you changhe
sensor-rotation speed
cyclic and rudder
or if you want to increase the pirouette
advanced-pirouette consistency.
It's normal that it doesn't arrive at the end of the stick.
Fly and you will see that the helicopter flies perfectly.
PostPosted: Mon 06. May 2024 17:53:44
mabe you are misunderstanding something wrong ?
With your stick you give an certain rotation rate - surer or later you will get the full deflection -
The swashplate will in half way of the rate maybe need double the time to get in the endpoint. If you give full stick you will have the half time of it - In other words the swashplate will stand still if you release the stick- you can test this with running motor on the workbench (without blades attached !) and you will see if you release the the stick, the swash will stay in this position - in the air you will see this reaction clearly - the most important with the cyclic ring is that that there is no binding at anytime if you are in minimum, middle and maximum collective stick - you can test this in the three positions as said and then make with your stick movement an full rotation -
PostPosted: Tue 07. May 2024 8:14:39
Hello and thank you all,
Mattes61 wrote:
With your stick you give an certain rotation rate - sooner or later you will get the full deflection -
You hit me the right way ... :D
Have a nice week ahead
