It is currently Tue 04. Jun 2024 17:14:27
PostPosted: Sat 22. Oct 2022 4:06:24
Hello I am having an issue with the governor on my Spirit2 and HW120V4 controlling headspeed when first turning off throttle hold. The headspeed will be way higher in all flight modes than they are set for. If I quickly turn throttle hold back on and off then all flight mode headspeeds all settle down to there proper rpms. I have checked and rechecked, setup throttle cut and tried turning it off then the hold with the same results. I just switched radios from my JR XG11 to a new NX10SE and all has worked out fine except this issue. The only thing after I get this sorted is working on a idle for autorotation bailout. Thanks for any help and insight into this weird issue. 8-)
Issue is fixed, my own stupidity was to blame. Somehow I used a Mod1 main gear 106 when doing the ratio and it is a mod.7 153 tooth main gear. With the proper ratio in place everything is working fine. Sorry for making you all read this. :oops:
Users browsing this forum: No registered users and 13 guests
