It is currently Mon 18. Feb 2019 5:52:34
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Wed 07. Jan 2015 19:57:39
Please proceed according the following steps:
1 - Right click to Start/open Device manager
2 - go to Ports (COM & LPT)
3 - Right click to Device Silicon Labs CP210x.
4 - Click to Tab Port Settings and open Advanced Settings
5 - open combo box with COM port ID
6 - select COM port with the lower possible value which is unused and click OK button.
7 - close the Device manager and start the Software, you should see COM port which was selected in device manager. In my case it was COM3.
Now, all should work without any issue. You have to connect cable from the interface to SYS position in the unit and connect the battery.
PostPosted: Sat 02. Feb 2019 4:09:37
Hi, I have a spirit pro that I can not connect to with the interface software. (Latest version)
1. Connected to the SP using Win 10 and updated the firmware to 2.6.1 worked OK.
2. Connected a Spektrum DSM2 RX and bound OK.
3. Restarted the SP and the software would not find the SP.
4. Have tried 3 different interface leads, 2 different windows PC (Win10) (Win7)
5. Successfully connected in recovery mode, but after flashing, the SP is not found by the software.
6. Successfully connect both PC'S to a non pro spirt, so the software, cables, all proven on a non pro spirit.
7. Have now run out of ideas!
Your assistance would be greatly appreciated.
PostPosted: Sat 02. Feb 2019 16:11:17
Please verify status LED of the Spirit unit. It should pulsate at the beginning and then steady on, once initialized. Can you confirm this?
It does not matter which unit it is. It must work with any Spirit unit.
PostPosted: Sat 02. Feb 2019 23:29:38
I have the same issue
have done what you say but still no connection
the unit has a slow on and off flash red light
com port 1
PostPosted: Mon 04. Feb 2019 8:13:30
The Status LED must be ON all the time when you are trying to connect. Normally this process takes just 6 seconds - initialization.
If it is not steady On, then it will unfortunately not work.
Can you confirm that after few seconds the Status LED is steady On?
This mean that you have to start the Spirit Settings software just when it is steady, not when it is pulsating.
PostPosted: Mon 04. Feb 2019 8:40:10
yes led is steady
but interface cant see the unit
PostPosted: Mon 04. Feb 2019 8:43:54
Good. When you unplug the USB interface from the computer, do you see still the same COM ports in the Spirit Settings software / Connection tab?
This mean you have to just unplug the USB and then re-launch the software.
PostPosted: Tue 05. Feb 2019 8:37:02
yes the coms port is the same
i think the unit has some sort of jam and the interface cant get past it
led is steady when i start up program
PostPosted: Tue 05. Feb 2019 11:23:05
Ah, no - if interfaces are still same this mean that the only issue is in the USB driver in your computer.
So the issue is not related with Spirit unit at all.
Please check this guide:
http://manual.spirit-system.com/index.p ... er_Windows
Especially at the bottom you can see the issue you are encountering right now.
It should be enough to reinstall the USB driver with the one from the Spirit Settings software.
PostPosted: Wed 06. Feb 2019 5:21:43
ok ,
done all of that
still nothing
removed all old sprit software and reinstalled
coms port shows driver working and coms port 1
tried std spirit unit and connects no problems
asks for me to update firmware,
not willing to do this yet .
tried different interface,still nothing interfaces are working as it can see the std spirit ,
seems the pro need a reboot
Ron
Users browsing this forum: Google [Bot] and 3 guests
cron
