It is currently Fri 29. Mar 2024 8:31:17
[ 5 posts ] |
EndoDusk
Posted: Tue 21. Jan 2020 0:11:12 |
Mikej
Posted: Tue 21. Jan 2020 22:25:25 |
Posted: Wed 22. Jan 2020 8:23:11 |
you have to connect ESC at the AUX1 port if you wish to use Governor. Throttle output must be enabled in the General/Channels window by assigning Throttle channel (1).
EndoDusk
Posted: Mon 10. Feb 2020 2:24:27 |
Thank you. I think it is working; I have the ESC output plugged into Spirit2 AUX port. I will update soon whether the FrSKY Neuron works correctly or not with governor.
thlu
Posted: Thu 14. May 2020 23:05:19 |
I also use the neuron ESC. My wiring is as described in this post. I use a taranis tranmitter, a x6r receiver ( futaba sbus), spirit pro 3.0.0 and the geolink Module. In my Transmitter i use the lua script for spirit configuration. The frsky esc is not listet in the menue for esc telemetry so i ordered a RPM sensor (Hobbywing RPM SENSOR HW86060041). The usb connection is not working. If i disconnect the s. Port from My esc the USB connection works. Is IT possible that there is conflict whith the telemetry ID. Idont wont to disconnect the esc every time if use the usb interface. Can anyone help.
[ 5 posts ] |
