Spirit System
http://spirit-system.com/phpBB3/
Tail Wag with Goblin 700 Gasser
http://spirit-system.com/phpBB3/viewtopic.php?f=20&t=3314
Author:  sputnic6 [ Tue 14. May 2019 19:54:38 ]
Post subject:  Tail Wag with Goblin 700 Gasser
I'm getting slight tail wag with the following setup:
Goblin 700 gasser
BK BLS-8005HV tail servo
rudder delay 0
rudder gain 38
Overall gain multiplier 1.0
If tired reducing the gain with no success. The mechanical is 90 degrees on the servo horn. Any help would be appreciated
Author:  sputnic6 [ Tue 14. May 2019 21:15:36 ]
Post subject:  Re: Tail Wag with Goblin 700 Gasser
I should also mention this happens in hover at 1900rpm, 2000rpm, and 2100rpm. From what I noticed, I do not get a wag doing pitch pumps.
Author:  ZeXx86 [ Wed 15. May 2019 21:16:11 ]
please try to increase Pirouette Consistency to 180 while decreasing Gyro Gain little bit.
Also using a shorter servo arm could help.
Make sure the unit is mounted really hard and can't move in any direction, especially to yaw due to vibrations.
Author:  sputnic6 [ Mon 20. May 2019 15:41:22 ]
I need to rebuild the engine. After that, I will try those settings.
http://www.phpbb.com/
