ZeXx86 wrote:
please make sure that when Servos/Subtrim (tuning) is ticked the servos are at the center position. At the same time swashplate is at the center position.
And at the same time there is 0° between main blades.
You might try to decrease Geometry 6° value little bit.
Alternatively please check vibration level with Spectrum Analysis - without blades. If there are extremely high vibrations then it could cause unexpected behavior and imprecision.
Hello!
I've followed all your suggestions:
- Servo and swashplate were in center position, blades are 0° when tuning is ticked
- There are only minimal vibrations shown. Even when hovering in the air there are no dangerous Vibration Levels shown in my Jeti telemetry-log.
- I decreased the Geometry 6° value a little bit but that was'n succesful either. The Heli felt more "wobbly" but the unwanted nick was still there.
Another user told me to try increasing Advanced/Elevator Filter Parameter, that I'll try the next time.
Do you have any other idea?
Edit: I've got a 4ds-File from another TDF-Pilot but that doesn't work with the 4ds-Browser (Message "Unsupported version: heli-2.5.2").
Is there any other way to compare these Settings with mine without loading them into my unit?
Thank you,
Thomas
