It is currently Wed 29. May 2024 5:12:01
[ 2 posts ] |
TheFlyingDJ
Posted: Sun 13. Jan 2019 8:31:15 |
Hello, I just recently received my Spirit Pro unit and I am trying to set it up with my DX6i. In the Setup Wizard I have run into an issue on the Diagnostic Panel. I run out of adjustment in my remote before I can get the endpoints to +/-100%. Is there a way to get around this? Any other tips and tricks for setting this up will also be very helpful. Also, my tail servo got very hot while working on this, so can I unplug it during the set up?
Specs: Spirit Pro, (2) DSMX Sats, DX6i, Align DS510M Cyclics, DS510 tail servo, Trex 500DFC
Posted: Sun 13. Jan 2019 20:27:33 |
if you are using Spektrum sats then it should basically work out of box - no need to set travel or other things.
The only thing you have to do is to change CCPM/Swashplate Mixing type to H1 / 90°. CCPM 120° mixing must be changed otherwise it will not work properly. Other than that you do not have to change anything in your radio.
New/clean profile in your radio is the best thing to begin with (with Mixing to H1).
Then in the Spirit unit you will need to set Spektrum DSM2/DSMX receiver type and finish the wizard.
[ 2 posts ] |
Users browsing this forum: No registered users and 23 guests |
