It is currently Wed 26. Jun 2019 9:26:09
 Post subject: geolink map orientation
PostPosted: Sun 07. Oct 2018 20:34:50
Hi, is the map always oriented northly or is there a possibility to rotate the map.
For instance, it would be very convenient to line up our runway with the bottom axis of the map in order to have the rectangular geofence aligned as well.
PostPosted: Sun 07. Oct 2018 20:51:44
the map is always oriented in the same way as it is used to be in any other map. For example Google Maps.
Regarding rotating this will be implemented for the rectangular area.
PostPosted: Sun 11. Nov 2018 19:50:48
Ah I think this answers my question as well, my field does not neatly face north/south so the rectangle will not work.
I assume by the post above it's coming in a later firmware update? (The ability to rotate the created rectangle).
Cheers
Tim
