It is currently Thu 21. Feb 2019 13:08:53
 Post subject: frsky temperature sensor
PostPosted: Fri 21. Sep 2018 12:10:15
hi,was wondering how i would go about wiring a frsky temp sensor,while already using frsky integration .the temp sensor has plug with 2 wires.smart port of x4r reciever has plug and cable that goes to spirit integration cable.could i join temp sensor cable to cable coming out of smartport?if so what wires would i need to join?sorry if it doesnt make alot of sense.help appreciated.thanks.
PostPosted: Sat 22. Sep 2018 8:27:56
basically you will need Y-cable at the side of S.PORT (receiver) and connect both FrSky integration cable and Temperature sensor together.
Or you can solder it together.
Users browsing this forum: Google [Bot] and 5 guests
