It is currently Tue 16. Apr 2024 7:40:07
PostPosted: Tue 10. Apr 2018 16:12:55
Hello now have the software you've sent me successfully and it works synonymous with the battery consumption in telemetry. What I unfortunately can not but is the Spektrum IX12 the Flybarless on the station set there is something to note or must be an update on the spectrum
PostPosted: Sat 14. Apr 2018 7:45:24
Hello as already asked several times the attitude of the spirit works directly over the Spetrum IX12 not only the telemetry will have to be transmitted as an update of spectrum or why does not work
PostPosted: Sat 14. Apr 2018 7:51:24
I am very sorry but I dont understand your question. Can you try to describe your problem?
Thank you
PostPosted: Sat 14. Apr 2018 9:43:47
I can not adjust the parameters of the Spirit with the new Spektrum IX12 as with the DX9 I have no menu which refers to the Spirit only the telemetry data is displayed by the Spirit
PostPosted: Mon 16. Apr 2018 14:26:07
Unfortunately we have no experience with IX12 yet. But I am sure that Spektrum can help you with how to enable the menu.
You have to find "Text Gen" or similar telemetry device in the menu first.
Can you see it there?
PostPosted: Mon 16. Apr 2018 16:03:23
Hello yes the menu Textgen I have but unfortunately there are no Spirit entries I hope now times spectrum comes in this regard an update
PostPosted: Sat 21. Apr 2018 6:15:13
I have an ix12. I have no issue entering the menu the same way you would on the dx series tx.
Sent from my SM-G955U using Tapatalk
PostPosted: Mon 23. Apr 2018 2:41:04
Hello you can tell me how you did exactly that you can do this
PostPosted: Mon 23. Apr 2018 11:38:29
You do have to make sure to have text gen assigned to be visible in the telemetry window. Aside from that I don't recollect doing anything different vs my dx. Run auto config, make sure text gen has a screen and is visible.
PostPosted: Mon 23. Apr 2018 19:05:24
Thanks for your help I have tried this unfortunately it does not work me I have in the telemetry field text only the display text 1 text 2, etc. uf which place do you have the telemetry text with me it is on the field 6 maybe the yes somewhere be different
Users browsing this forum: No registered users and 14 guests
