It is currently Fri 19. Apr 2024 18:51:46
PostPosted: Sun 08. Apr 2018 3:59:00
Hi ZeXx86,
It's me again with a brand new heli and a brand new problem.
I have a new Synergy 516 heli where the the motor keeps stopping mid flight at random, the servos still work fine so six autos later it is still not broken :)
I have attached the log from the Spirit and I was hoping you may be able to give me a clue with regards to the problem.
I am not using the Spirit governor but I am using the governor store one on the Hobbywing 100A ESC, I have a feeling the new ESC may be the problem but I'm hoping these logs may help.
Thanks in advance once again.
spirit-log-2018-04-08-120232.pdf [83.93 KiB]
Downloaded 57 times
PostPosted: Sun 08. Apr 2018 10:37:05
for sure we can help.
The log looks strange - are you flying for 40 minutes?
Is the Governor enabled in the unit? It must be disabled if governor from the ESC is used.
PostPosted: Sun 08. Apr 2018 11:25:56
I thought it was strange as well.
Only using the governor in the Hobbywing, the Spirit one is off.
Flew one pack without issues, waited around for a while and then flew a two minute flight before the motor stopped, waited 10min and then flew for another 2 min without issues with the same battery.
Got home, downloaded the log and scratched my head.
PostPosted: Sun 22. Apr 2018 12:05:28
For those wondering, the receiver was faulty and was causing the weird issues.
Swapped it out and no more troubles.
Cheers!
PostPosted: Wed 25. Apr 2018 7:16:06
Thank you for your great and helpful message!
Users browsing this forum: No registered users and 56 guests
