It is currently Thu 28. Mar 2024 16:12:24
[ 6 posts ] |
keeny
Posted: Tue 06. Mar 2018 20:17:02 |
Been away for a short while anyways on my 500 align heli when I plug the batt in it goes nuts for a couple of seconds and then stops...then initializes like normal. I have recently replaced like for like servo..... any ideas? Cheers, Chris.
Posted: Tue 06. Mar 2018 20:37:58 |
it look like some BEC related issue. Could you disconnect all servos (and anything that is not necessary) and try it again?
keeny
Posted: Wed 07. Mar 2018 16:00:04 |
Thanks for the reply. I disconnected all the servos then plugged in one at a time which resulted in an initial short movement then the up and down bit, the last servo which is a new replacement dipped down when the others went up when first plugging in the battery. then when I do bailout in quick succession it bounces very quickly at each limit up and down. could this be a problem with the new servo or have I missed some setting. I didn't change any settings as the servo is an exact replacement and even centres in the exact same place. Cheers, Chris. ps, all the movements and bailout are going the correct way.
Posted: Wed 07. Mar 2018 22:47:12 |
Unfortunately it look like a servo issue. This should really not happen at any moment. I guess that it is causing a short during these events and probably BEC is restarting as safety protection.
The only servos we have experience that were doing a very similar things were from BK.
keeny
Posted: Tue 13. Mar 2018 19:53:23 |
Finally got around to stripping new align servo down and there was a grumpy gear in there that you couldn't really feel when assembled. Changed the gear and all is well.
Posted: Wed 14. Mar 2018 10:29:54 |
Thank you for great message!
Good to know it is working well now.
[ 6 posts ] |
Users browsing this forum: atamargo and 1 guest |
