It is currently Tue 16. Apr 2024 18:27:24
 Post subject: Frsky Fros Telemetry
PostPosted: Sun 18. Feb 2018 3:18:55
I was hoping to get a little help setting up telemetry on a Horus X10s with standard Fros. I am aware that I will not be able to get integration with out opentx which is fine but want to get the telemetry figured out.
I have a spirit pro, Hobby wing 160, currently a X4R but will be switching to an RX8R and Telem Uni cable.
I am making the switch from Spektrum and I was getting all the telemetry on the DX9 setup. Currently I have the pro connected to receiver thru Sbus, and the Telem UNI cable connected to main spektrum port on the pro and into the ESC. Is this correct or am I missing a cable?
Thanks,
Ben
 Post subject: Re: Frsky Fros Telemetry
PostPosted: Sun 18. Feb 2018 10:25:52
you will need the FrSky integration cable to make it work.
Basically everything is same as for the OpenTX, except you will not get the integration. But telemetry is using the same bus, so you will still need the integration cable.
You can proceed according this guide regarding Wiring:
http://manual.spirit-system.com/index.p ... ntegration
PostPosted: Sun 18. Feb 2018 16:16:32
Thanks for the response.
So just to be clear I will keep sbus and telem uni connected as is then add the frsky integration cable?
PostPosted: Sun 18. Feb 2018 16:30:19
Yes, you are right.
Users browsing this forum: No registered users and 14 guests
