It is currently Tue 16. Apr 2024 10:09:41
 Post subject: Spirit pro problem
PostPosted: Wed 18. Oct 2017 0:27:18
i have a spirit pro + x8r + taranis ... connect with s-bus with straigt cable all work good and today i try to open my heli and i have initialisation problem... the light slow blink red ... after 30-45 sec the system initialise swash move ok and another 1 min later all control stop ... i wait another 10 sec all was back, after 30 sec all control stop ... i try to connect in usb i see the control no log error and after 30-45 sec the connection usb was lost and i need to remove power and restart all for the same result ... i have try to reset the unity and same problem ... my spirit was broke ? i dont have crash or nothing special with it .. help will be aapreciated
 Post subject: Re: Spirit pro problem
PostPosted: Wed 18. Oct 2017 9:39:51
was there any wiring changes prior this problem? Anything that changed could cause the problem.
Can you disconnect all servos and everything that is not necessary (all except ESC/BEC)?
PostPosted: Wed 18. Oct 2017 12:25:49
i have try what you said and same thing slow red blink long time to initialise,make error ( head jumping few time) can connect to the pc with usb but after 10-20 sec lost connection a i need to reboot all for work again 10-20 sec .. i have try a link usb cable from my friend and same problem ... the only thing that change in wire it's the day before i make error and i plug the bec in aux2 insted of aux1 but in the manual it's not suppose to damage the unit i could not figure the problem :/ it's seem to be with the sys port
Last edited by GoblinShefford on Thu 19. Oct 2017 2:17:50, edited 1 time in total.
PostPosted: Thu 19. Oct 2017 2:15:05
i have try other thing .... ok lets me describe better than previous ...
i plug my batt in the bec... the spiritpro slow red blink take time to initalise ... i have a bec talon 90 he make only 6 bip (detect my 6s batt) and that's all ... no other sound same as habitually .... after few other second the spirit initialise ... i can connect in usb and all servo work ... if i play all the time with the cyclic the servo and usb connection dont stop working ... but when i dont touch Nothing 2-3 sec. the spirit pro stop work but the light always red ... if i play with the cyclic Nothing work ... but if i continu to play with cyclic after few second the spirit pro respond i can reconnect with usb and servo work ... when i never disconnect the spiritpro i can see in log file
00:00 calibration finished
Main loop hang occured
00:10 Main loop hang occured
00:20 cyclic ring activated
00:30 cyclic ring activated
Recivied frame was corupted
00:40 cyclic ring activated
00:50 cyclic ring activated
01:00 Main loop hang occured
01:10 cyclic ring activated
PostPosted: Thu 19. Oct 2017 7:38:46
Thank you for your info.
Unfortunately Main Loop Hand event is indicating some very important problem. If nothing is in the unit except USB interface and BEC, then I fear something happened to unit.
Plugging power to AUX2 is not a problem. Only if red and black wires are swapped.
Do you think you can send the unit to us?
We will fix it in one day and find what happened.
PostPosted: Thu 19. Oct 2017 13:16:36
to this adress ?
Spirit System
Tomas Jedrzejek
K Olsine 28
73514 Orlova-Lutyne
Czech Republic
PostPosted: Thu 19. Oct 2017 13:31:48
Yes, please.
Where are you from? If it is outside of EU, please declare package value under 25 USD to allow easy customs.
Users browsing this forum: No registered users and 12 guests
