It is currently Tue 16. Apr 2024 20:44:08
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Fri 15. Sep 2017 10:16:59
Hi BT
Thanks for testing. Have you forced a log record before doing the test by switching off the TX while RX is armed?
I have found it's hard to get a signal loss record if there is no log stored, but once there is a stored log it happens more frequent.
If you still don't see issues, where does our setup differ?
X6R(1) FW LBT_151118
X6R(2) FW EU_170210
Spirit 2.4.2 and 2.4.4
TX Horus X12S with OpenTX 2.2.0 running on EU FW
Failsafe configured as [Custom] in Horus for RX.
many thanks, Adrian
PostPosted: Fri 15. Sep 2017 11:48:09
Hi Adrian,
I have prepared firmware with small modification.
There the Log will be never cleared even after viewing the events.
It could help us little bit in understanding where the problem is:
http://spirit-system.com/dl/fw/spirit-fw-2.4.25.4df
Hopefully it will not happen with this firmware. If it will, then it is possible that the problem is in the receiver firmware.
PostPosted: Fri 15. Sep 2017 20:30:21
Hi Tomas
With this FW 2.4.25 there is no signal lost with LogView.lua
But I can get signal Lost doing Bank switch in basic.lua
As you said, Logview.lua does not clear the log.
Afterwards I did open Log with WinPC and USB Interface.
In the very same moment where the Warning popped up about previous Log, Spirit went into FailSafe.
But it's not happening always. Once it works, its also clearing the log.
regards, Adrian
PostPosted: Sun 17. Sep 2017 22:08:45
Hi Adrian,
thank you very much for the message!
It was really helpfull.
Maybe we will find solution tommorow.
PostPosted: Wed 20. Sep 2017 7:39:47
Hi Adrian,
please try this firmware:
http://spirit-system.com/dl/fw/spirit-fw-2.4.5.4df
Hopefully it will help :) Thank you very much!
PostPosted: Wed 20. Sep 2017 19:32:21
I got the feeling it got better, but I do still get the Failsafe. On every 3-4 Bankswitches as well as on LogView.lua
An other observation, doing Pitch movement during Bankswitch in LUA the servos do sometimes move jerky and even system goes into Failsafe.
Users browsing this forum: No registered users and 13 guests
